Random dead battery issue
Old Jan 6, 2017 | 03:48 AM
gorecp's Avatar
Default Random dead battery issue
This is a recent issue.. I drained my battery a few weeks ago and had to recharge it. It was a slow 2 amp trickle charge.. . since then I've had random instances of when the car was off for any random period of time and I'd go to start it there was nothing
no interior lights.etc. most recently tonight. I turned it off. To disable running lights. Went to restart and nothing.. dead as dead can be.. yet.... pop off the negative terminal and replace it everything is right as rain
csr starts again.
battery is new as of early 2016 and and tests fine . Alternator is fine etc..
only happens when csr is out in cold as its never happened starting in garage
any insight would be greatly appreciated
Old Jan 6, 2017 | 10:42 AM
ccernst's Avatar
is this a maintenance or maintenance-free battery? if you can open the cells, make sure it has correct water levels.
sometimes when a battery is drained, it does kill the battery.
KF97diamonte
May 5, 2010 01:38 PM
stbentoak
4th Generation
Apr 12, 2008 07:25 PM
wfewife
Jan 28, 2008 06:33 PM
wfewife
nyc95gst
Nov 16, 2007 04:30 PM
