Rear running lights not working but brake lights do
Old Dec 30, 2020 | 06:27 AM
  #21
Igor Zupan's Avatar
Smile Rear light right not working but break light is ok
I had similar problem with rear light. I found out that right rear light is linked with glove box lamp and left one with licence plate light. When I change left and right light the problem remain. I checked the voltage between black line and light green (rear light) I got 6V stable (if lights were on or off) and during the break light showed 12 V. I discovered that the lamp in glove box is broken. I bought is new (1.2 W) for 0,70 EUR. After the replacment light was ok and had 12 V when is on and 0 V when was off. Problem resolved.
When I asked the workshop I got no idea about the problem, they just said that problem can be linked with electricity for the trailer. In my case I have no trailer instalation.
Old Oct 5, 2021 | 07:52 PM
  #22
wendigee's Avatar
Smile This Worked!
Originally Posted by Outland11
Had the same problem... both license plate bulbs were burned out. Replaced them and the tail light is now working
Thank you all for posting these suggestions. I replaced the license plate lights and the taillights came back on too. Now I can get it inspected!!!
Old Dec 28, 2021 | 12:01 AM
  #23
Theantspants's Avatar
Thanks heaps guys. I almost bought a new tail light lens but researched first and found this thread. found the burnt out glove box globe and its all fixed for $7
Old Jan 12, 2022 | 10:08 PM
  #24
ClemASX's Avatar
Originally Posted by Cacross01
Okay so I have a 2011 Mitsubishi outlander an had the same problem with the tail light...running light didn't work but the break light would..so I checked all the lights around the car an over looked a light. In the front head light it's a small orange build..I replaced it an my tail light came back on
Thank you for this! I have a ASX, with the exact same problem. Driver side taillight blinked a sec, and stopped working, but brake lights worked. Initially brought my car to replace the led set ($80), realized it wasn't the issue when I plugged the new one in. While checking all lights, in case it was a wiring issue, I remembered this post, mentioning the 'small orange(ember)' light not working. True enough, I had the same problem at the driver's side front parking light. Changed the front 'small orange(ember) E6 bulb, (60cents !!!!!!) and bam! the rear taillight came back on.
Really thank you for this!
Old Nov 26, 2022 | 12:51 PM
  #25
yumalhot's Avatar
Originally Posted by Dcfire4
Had the exact same problem. Also even thought about wiring it across. Came upon this thread. Noticed my license plate lights were out also. Replaced them. Boom!! Tail light works!!!! Thank you soo much outland11!!!!
Dude!! This was a life saver. I changed the fuze and the tail light but still nothing. Changed the license plate light and got it running all the way.
Thank you for posting this.
Old Sep 7, 2023 | 06:29 AM
  #26
Giopiste's Avatar
Default soluzione
I fixed it by replacing the license plate light bulbs and the glove box light bulb.
Old Jun 10, 2024 | 02:09 AM
  #27
argoso's Avatar
I just bought a 2011 Outlander. The tail light on the rear passenger side was not working as it should and was only burning gently. When I pressed the brake, the LEDs all lit up beautifully. The voltage at the contact was only 7V. The other (driver's side) plug has 12V. I swapped the lights and the light delivered as needed. The rear number lights were fine. There are no bulbs in the glove box on this machine. However, the first cab light, which was also on the side of the passenger, did not work. Its bulb was burned out, and after changing it, the taillight also started working beautifully.
Old Sep 19, 2024 | 10:12 AM
  #28
KingElvisH's Avatar
Default Same annoying problem with the tail light LED’S!!!!
[QUOTE=guidofer;328114]OULAND11 I had the same problem and fixed it with your solution... THANK YOU![/
You Have saved me and many more aggravation, time and more importantly MONEY!!!! Thank you X 100!!!!
Old Sep 24, 2024 | 08:50 PM
  #29
jlw2020's Avatar
Default Partially solved
Thanks Mitsi forum. L/H front and rear parking lights weren't turning on. Also noticed plate lights were gone after reading this forum. Replaced plate lights and now the rear park lights work. Someone else suggested the glove box light, which needed replacing. However, that did not do the trick for the front park lights. It does seem like an electrics issue because as I was messing about with fuses/relays etc the front left park light did come on for a bit. But then next time I tried it was off again.
Thanks for the help legends.
Old Feb 27, 2026 | 12:38 AM
  #30
Daggerscript's Avatar
Interestingly right license plate, glove compartment and tail light all were not working.
Replaced license plate lights (both) and glove compartment with (74) bulb. But tail light RH is still not working along with the brake.
swb0510
Apr 24, 2013 10:16 PM
thej001
Aug 1, 2010 03:28 AM
milkmaan
Aug 24, 2009 10:20 PM
praetorian20
Apr 11, 2009 12:15 PM
Pokerdude
Oct 22, 2007 08:31 PM
