Recommended Tire Pressure?
Old Jul 10, 2012 | 01:05 PM
OutlanderGT's Avatar
Default Recommended Tire Pressure?
what tire pressure do you recommend?
I have the GT AWD curb weight is about 3,780 lbs
the door sticker says 35 psi
I took it in to the dealer for a checkup, the techician put down on the paperwork the tires are checked and set at 32 psi now.
Is it ok to deviate a few PSI from the sticker on the door?
Old Jul 10, 2012 | 08:51 PM
firebuck's Avatar
Stock size rims and tires?
Old Jul 10, 2012 | 10:19 PM
Yes, I think it is 225/55/18
I went home and check at noon it reads about 37 Psi all around.
Old Jul 11, 2012 | 07:00 PM
ccernst's Avatar
your psi will fluctuate as your tires heat up / cool down. a few pounds one way or the other won't hurt. I usually keep mine at 36 lbs.
Old Jul 11, 2012 | 08:34 PM
firebuck's Avatar
Good advice. Just try to keep it close.
Old Jul 12, 2012 | 02:28 PM
11SE2HEAR's Avatar
I have been told by my local performance tire shop that they inflate their tires they mount to 10% below that max pressure rating on the sidewall of the tire when cold, not by the "comfort" rating in the doorjam. Seems to work for me just fine and the outer edges of the tires don't wear as quickly.
Old Jul 12, 2012 | 03:33 PM
That's probably about 40 PSI+
I would think you sacrifice some traction and a harsh ride that way. But you will get a little better gas mileage. It might also be an advice given to sports cars because they have low profile tires (45 aspect ratio or less) and overinflating will reduce chances of bending a rim.
I wonder what happens when you inflat the tire to 10% less than maximum at sea level
and take it to 9000 ft mountain summit, would the tire be very overinflated then?
Old Jul 13, 2012 | 01:07 PM
11SE2HEAR's Avatar
Here in the desert the roads are good and almost always dry, so traction really isn't an issue so to speak. Sure the ride is a little more stiff. But not a big deal to me. Haven't really checked the pressure from low elevation to a higher elevation. Maybe next time I head to the higher elevations I'll check.
I've been inflating my stock Goodyears between 40-41psi.
outiehere
Oct 18, 2007 10:36 AM
GITRDUN
Oct 17, 2007 05:00 PM
benchman
13
Sep 10, 2007 12:21 AM
GTAlander
Aug 24, 2005 12:15 PM
Maximus99
May 17, 2005 06:14 AM
