Speakers
Old 08-16-2006 | 07:14 PM
kutapio's Avatar
Default Speakers
Hi, for those who have changed speakers what size speakers do outlanders have? are the front door ones the same size as the rear ones? Also did you have to change the plugs used with the wirings? Thanks!
Old 08-16-2006 | 08:05 PM
dirtwagon's Avatar
Default RE: Speakers
If I'm not mistaken, 6.5" speakers are both front and back door, with 1" tweeters on the A pillars- if they came with it. If not, install some while you're changing the door speakers, it's easy. The plugs may need to be modified as they are designed for the stock speakers, but a pair of cutting pliers and new connectors will make easy work of those.
Good luck and let us know what you end up doing.
shamsulaswad
03-18-2006 02:00 PM
Flipz
08-10-2005 11:13 AM
crunchie
05-03-2005 04:21 PM
aswahdan
11-12-2004 11:25 AM
velcrobots
11-15-2003 08:28 PM
