Speakers
Old Aug 16, 2006 | 06:14 PM
kutapio's Avatar
Default Speakers
Hi, for those who have changed speakers what size speakers do outlanders have? are the front door ones the same size as the rear ones? Also did you have to change the plugs used with the wirings? Thanks!
Old Aug 16, 2006 | 07:05 PM
dirtwagon's Avatar
Default RE: Speakers
If I'm not mistaken, 6.5" speakers are both front and back door, with 1" tweeters on the A pillars- if they came with it. If not, install some while you're changing the door speakers, it's easy. The plugs may need to be modified as they are designed for the stock speakers, but a pair of cutting pliers and new connectors will make easy work of those.
Good luck and let us know what you end up doing.
shamsulaswad
Mar 18, 2006 01:00 PM
Flipz
Aug 10, 2005 10:13 AM
crunchie
May 3, 2005 03:21 PM
aswahdan
Nov 12, 2004 10:25 AM
velcrobots
Nov 15, 2003 07:28 PM
