Thinkin of buying
Old Feb 28, 2013 | 12:49 PM
RNS101's Avatar
Default Thinkin of buying
Hey there
at the moment i have p38 range rover 2.5td auto i tow a caravan n do a little off roading.
what sort of mpg would i be getting around town and towing (2000kg) caravan
also how well off road is the outlander could it manage some green lanes IE in wales n so on
Thanks
Ryan smith
would be lookin at getting an Auto
Old Feb 28, 2013 | 03:38 PM
ruski's Avatar
I have seen someone towing a boat behind their Outlander. It looked a bit awkward.
But not as awkward as someone towing a boat behind their Cadillac CTS.
Old Mar 1, 2013 | 02:22 AM
tinker's Avatar
I have 2.0d-id, think it would struggle with that caravan, but I have never towed with it, is it the 2.2 u would be buying.
I would stick with the RR stable
Old Mar 3, 2013 | 11:09 PM
ckmecha's Avatar
2000kg=4400lbs is above the rated tow capacity of the Outlander even with trailer brakes. I wouldnt attempt that much.
I do however tow almost weekly with my Outlander up to about 1000lbs. I dont see a noticeable dip in my mpg as mostly im towing on surface streets.
And when I tow my sailboats behind my Outlander it looks right at home. Suppose I should take pictures.
Old Mar 4, 2013 | 10:26 PM
ivanz's Avatar
Honestly, I wouldn't trust the OEM brake setup with the Outlander. It would need to be beefed up for *me* to tow something that heavy. Then again, the highway out of where I live has a long 8.5% grade section. Flatter terrain should be fine. I don't believe you'll have issues moving with the 3.0L V6 or the diesel versions. I would recommending not even looking at the one with the 2L VW TDi, as it has a known design fault (self destructing turbo).
Then you will have to look into suspension issues depending on the tongue weight of the trailer. You will need to beef up the rear suspension with an airbag or something to prevent it from bottoming out if it is too heavy.
As for off roading, Outlander has firmer suspension than most cars I have driven. It will be a bumpy ride to say the least...
So its do-able, but you need to figure out what you are towing and what you mean by off-road. Then look at the terrain you travel for the brakes.
jthorn75
Jun 21, 2012 10:01 AM
reggieccrgto
Oct 6, 2008 07:53 PM
hatchetman9449
Apr 10, 2007 11:54 PM
RancidSam
Nov 13, 2004 03:22 PM
