Thinner oils used in '11+ ?
Old Nov 17, 2012 | 11:48 AM
ccernst's Avatar
Default Thinner oils used in '11+ ?
I was playing around on on Amsoil's site and looking at the fluids for my '07 and I wondered what a '12 would use. Same engine (except different pistons to reduce chamber volume for extra power) used througout, but in '11 they started to use 0w20. '07 through '10 they recommended 5w20. Got me thinking about trying out a 0w20 and seeing if there will be any fuel economy improvements. Stuff is same price at walmart. Can you guys with the '11 or '12 models with 3.0L verify if you should use 0w20?
Old Nov 17, 2012 | 02:34 PM
milliesdad's Avatar
My '11 4 cyl was 0w-20. My '12 3.0 is 5w-50
Old Nov 20, 2012 | 11:26 AM
nesser's Avatar
There was a TSB from Mitsubishi about changing the oil viscosity for 2011 on. I don't think it applied to anything before then - not sure why. Check with your dealers service advisor and see if they have an answer for why.
I just put in a fresh batch of 5W-20 last week. I'm not convinced the 0W-20 would give all that much more fuel economy even with our cold winters. It would probably be hard to measure but if you do a lot of short tripping then maybe.
Old Dec 6, 2012 | 04:49 AM
Josemora's Avatar
You must better go for teh 5W-20, as you have told that you have put a fresh batch of 5W-20. because 0W-20is not better in the winters.
Old Dec 18, 2012 | 06:52 PM
OutlanderGT's Avatar
On a 2012 GT it is 5W20 in the manual, and 5W20 on the sticker under the hood.
Old Dec 18, 2012 | 07:08 PM
quadcam's Avatar
Here it is 5W40 for the 2012 3.0L
redturboeclipse
13
Mar 8, 2015 11:09 PM
GreyNomad
Aug 25, 2013 09:37 PM
GAMonteroSport02
Aug 3, 2007 05:29 AM
YonkersMitsuJoe
Jul 6, 2006 03:27 PM
starion parts
Aug 27, 2004 06:03 AM
