Timing Belt kit/ advice
Old Nov 13, 2017 | 04:14 PM
ccernst's Avatar
got any more information than that?? two valves per cylinder? total? how long were you on the old belt? what did the pistons look like for those that were bent?
Old Nov 13, 2017 | 04:34 PM
MattReed59's Avatar
The 2007 Outlander is a 24 valve V6, so yes, two valves per cylinder. It was the intakes for cylinder 6. The pistons looked find, no marks or anything, but the engine was up to temperature and on the highway doing 70 so the valves were pretty hot.
The car had ~140K miles and I had replaced the belt at 106K, but I didn't know the trick with the tensioner at first and so I probably damaged the belt when trying to get it on. I had replaced the water pump at the same time.
What is the trick with the tensioner you ask?
When installing the belt remove the top bolt from the tensioner (after you compress it carefully and put a pin in it) and rotate the tensioner counter-clockwise. This lets the tension pulley drop down and gives you enough room to install the belt. After the belt is installed rotate the tensioner back in place the put in the bolts.
-Matt
n.w.m
Jul 16, 2017 12:09 PM
archersofloaf
Aug 14, 2016 10:46 PM
kingarfer
Feb 19, 2008 11:05 AM
8000RPMS
Aug 30, 2007 05:49 AM
jneumann
Dec 20, 2005 05:39 AM
