help w/ 07 xls lower front motor mount
Old Aug 18, 2017 | 10:16 AM
07xlsguy's Avatar
Default help w/ 07 xls lower front motor mount
Hello all
I havr to replace the lower front motor mount on my 07 outlander xls. This is the mount you see when you open the hood and look straight down under the radiator. looks connected to cross member?
Has anyone replaced this and how easy is it? It almost looks like too easy--- floor jack with wood block under motor and take bolts out... im assuming no additional support is needed since UPPER left and right mounts should support the engine-- am I wrong?
Thanks very much
Old Aug 18, 2017 | 05:50 PM
ccernst's Avatar
Sounds right to me...
Old Aug 21, 2017 | 03:51 PM
binzd's Avatar
Default Pics from Manual
Seems pretty simple. Please post if there's a trick or discovery while doing.
Attached Thumbnails help w/ 07 xls lower front motor mount-centermember.jpg   help w/ 07 xls lower front motor mount-front-mount.jpg
Old Nov 14, 2017 | 10:43 AM
WHITEOUT2010's Avatar
How did it go? I might have to do mine. Any input is appreciated. Thanks!
nathan320gauge
Aug 15, 2014 01:03 AM
mikemitsu
Jan 25, 2013 08:14 PM
Eclipse440
May 17, 2012 10:23 PM
Gstfat
Jun 11, 2007 10:10 PM
timot
1st Generation
Mar 21, 2006 03:14 AM
