TMPS change problem
Old Mar 21, 2009 | 02:48 PM
red123's Avatar
Default TMPS change problem
So I just had my tires change last month and have a question. I looked and the OEM TMPS sells aournd $50 each.
I went to discount tire and they told me for every tire replacement they need to change the tmps also due to wear? So they took out the oem tmps and install the new tmps kit from them but not oem.
Should they took out the OEM, replace the tires, then put back on the OEM tmps? Should they gave me back the OEM TMPS?
After the checkout i don't remember they giving back the original tmps...
Im not sure that the OEM TMPS is neccessary. Help!
________
Iolite vaporizer review
Old Mar 21, 2009 | 09:57 PM
azjake's Avatar
Not sure what discount meant by "wear" on the tpms sensors. That doesn't sound right.
I checked the manual for my 08 ES and the only thing mitsu recommends replacing is the grommets and washers that hold the sensor in place when tires are changed, but not the sensor itself. I know there have been persons on this forum who have re-installed the oem tpms sensors on aftermarket or winter tires with no problems.
Old Mar 22, 2009 | 07:57 PM
azjake's Avatar
I found this website that gives a lot of information on the mitsubishi TPMS.
http://www.mitsubishi-tpms.com/
Victoria Chapman
May 22, 2012 11:04 PM
Chiups
Nov 30, 2011 03:42 PM
Yury
Apr 18, 2011 10:47 AM
enzo_hashmat2006
Aug 16, 2005 06:43 PM
jgmacdaddy
Jan 9, 2005 12:49 AM
