torque setting for an oil plug
Hi,
This is from the service manual:
Oil pump
Oil spray jet bolt
25 N·m
Oil pump sprocket bolt
20 N·m → +90°
Oil drain plug
30 N·m
Oil sump bolts
15 N·m
Baffle plate bolts
15 N·m
Suction line bolts
15 N·m
Chain tensioner with tensioning rail bolt
15 N·m
Sealing flange bolt
15 N·m
Oil filter bracket
Bracket bolt
10 N·m
Plug
25 N·m
Sealing cap
25 N·m
Oil pressure switch
22 N·m
Oil supply line
22 N·m
Connection
30 N·m
Oil pump
Oil spray jet bolt
25 N·m
20 N·m → +90°
Oil drain plug
30 N·m
Oil sump bolts
15 N·m
Baffle plate bolts
15 N·m
Suction line bolts
15 N·m
15 N·m
Sealing flange bolt
15 N·m
Oil filter bracket
Bracket bolt
10 N·m
Plug
25 N·m
Sealing cap
25 N·m
Oil pressure switch
22 N·m
Oil supply line
22 N·m
Connection
30 N·m
