towing with a 2007 outlander
I'm hoping someone could help me I have a 2007 outlander with a 6 cyl automatic trans. front wheeldrive the towing capacity is 2000lbs i just bought a boat the total weight of the boat and the trailer is 300lbs over capacity of the towing weight for my outlander is there anything i could do increase the towing capacity. it does sit alittle low if i install air shocks or air bags would that make any difference.
There are certainly things you can do. Weigh the tongue of the trailer and see how that correlates to the load rating. If the trailer is well balanced leading to a low tongue weight, adding trailer brakes to the trailer is going to allow you to tow significantly more. You will be amazed at how much better a balanced load is to haul.
Ive towed much more with much less as well. I recently helped my brother tow a 3600lb car with a Jeep Liberty over 200 miles. The only issue we had the whole way was a trailer tire that had a slow leak.
Back when I was young and dumb i towed a 20' cabin cruiser from DC to Atlanta with a 4cyl two wheel drive Ranger. Not a single issue.
Keep it below 60 and be cautious and youll be fine.
