towing with a 2007 outlander
Old Apr 25, 2013 | 04:27 PM
mit1236's Avatar
Default towing with a 2007 outlander
I'm hoping someone could help me I have a 2007 outlander with a 6 cyl automatic trans. front wheeldrive the towing capacity is 2000lbs i just bought a boat the total weight of the boat and the trailer is 300lbs over capacity of the towing weight for my outlander is there anything i could do increase the towing capacity. it does sit alittle low if i install air shocks or air bags would that make any difference.
Old Apr 25, 2013 | 07:42 PM
Absolutely not.
Old Apr 26, 2013 | 08:43 AM
milliesdad's Avatar
It has to do with final drive gering, cooling system capacity and transmission oil cooling.
If the manual says 2000 lb, I'd beleive it.
My 2012 GT (swac,6 spd auto, 3.0 V6) is rated for 3500.
Old Apr 26, 2013 | 09:44 AM
mit1236's Avatar
Thanks I figured that but I was hoping that there was some type of upgrade that would help.thanks for the reply
Old Apr 26, 2013 | 10:09 AM
You're welcome.
Also don't forget brakes. Downhill + towing a 2000lb load, you'll struggle to stop the thing.
Old Apr 26, 2013 | 09:12 PM
quadcam's Avatar
I would have thought traction would be more the problem. A wet boat ramp, front wheel drive and trailer weight could not be a good combination.
Old Apr 26, 2013 | 09:26 PM
These days with the mandatory traction control systems, slipping wheels aren't too much of a problem for your average idiot driver.
However, your point stands true... that'd sure make for a tricky exit.
Old May 6, 2013 | 04:22 PM
ckmecha's Avatar
There are certainly things you can do. Weigh the tongue of the trailer and see how that correlates to the load rating. If the trailer is well balanced leading to a low tongue weight, adding trailer brakes to the trailer is going to allow you to tow significantly more. You will be amazed at how much better a balanced load is to haul.
Ive towed much more with much less as well. I recently helped my brother tow a 3600lb car with a Jeep Liberty over 200 miles. The only issue we had the whole way was a trailer tire that had a slow leak.
Back when I was young and dumb i towed a 20' cabin cruiser from DC to Atlanta with a 4cyl two wheel drive Ranger. Not a single issue.
Keep it below 60 and be cautious and youll be fine.
QwikEVO
Nov 10, 2015 08:37 AM
westoncp
Aug 15, 2011 06:05 PM
Incisen
Jul 18, 2011 08:48 AM
smo18
Sep 29, 2008 12:07 PM
1lowclipse
Sep 10, 2004 05:54 PM
