Transmission/Differntial Fluid Change
Looks like they did a simple drain and fill, so you'll have a bunch of old fluid in there still.
J1 For me at my dealer is $100, 4L. To do a proper Flush uyou need 8L, so at least $200 in tranny fluid + labour. Plus Im assuming the J3 is more expensive
I would ask the service guy to clarify what they did, I hate the term "fuild service" that means a million possibilites but lets the service dept basically pick and choose what they do.
Even if it was a drain & fill, the car only had about 50k on it so I'm sure the fluid wasn't that bad to begin with.
Mark
drain and fill
I did a drain and fill on mine at about 52k kms. About 3.5 liters came out and i put the same amount back in. Diaqueen J2 ATF from the dealer at $18Cdn/liter. The fluid that came out was slightly darker than the fluid going in but not really dirty at all. If you do a drain fill every 50k kms the transmission should last the life of the vehicle, from my observation. If you tow with it, I would drain-fill every year.
Some people in here are talking about $10-12 per quart/litre. If that's correct then the dealer used about 10 litres to do the fluid service. (At the $25 per litre, they would have used about 5 litres) Next time I'm at the dealer, I'll ask for a price for the J3 and ask whether they did the flush or drain & fill.
Mark
Mark
Mark
Mark
If they charge $128 for the tranny service, all of that is not for fluid.
Either way, I will ask for the details next time I am at the dealership.
Mark
MitJsus
10-04-2010 05:51 PM
05, 75w90, change, changed, diferencial, differential, fluid, front, gear, mitsubishi, oil, outlander, sp, sti, suppose
