TSB regarding the "clunk"
Old Jan 8, 2008 | 02:16 PM
bxfang's Avatar
Default RE: TSB regarding the "clunk"
I have a 2007 outlander for a year. There is a loud "clunk" noise even when it was brand new. The noise just happens when you turn on the engine and start to move the car at about 3-5mile/hr. It doesn’t matter which direction that you are going. The noise will not repeat until you shut off the engine then turn it back on again. The noise was quite loud so that you fell like something broken or two metal pieces hit each other hardly. Now, the noise seem to be not loud as the beginning, but you are still able to hear it clearly at every time you turn on the engine and start to move the car. I brought my outlander to the dealer yesterday. They just replaced bearings as on the TSB, but when I got my car the problem is still there. They told me the problem that I have happens on all the 07 outlander. Is any one has same problem here? Any way, the dealer is going to show me the “clunk” noise on the new outlander on this weekend. Hopefully, he is right.
Old Jan 8, 2008 | 08:25 PM
blackb13's Avatar
Can a moderator make this a "sticky?" It's getting asked every week...
GROUP 35 Service Brakes : ABS Pump Noise (Update): 2006-07 Eclipse, 2007 Eclipse Spyder and Outlander : ABS System Conducts a self-check to ensure it is functioning properly the first time the vehicle reaches approx 2.5 mph. During the self check, a "clunking" noise will be heard from the right front of the engine compartment. The noise only occurs the first time the vehicle is driven after the engine is started. It will not reoccur until the engine is restarted. This noise is a normal operation of the ABS System. Do not attempt to repair this condition.
Old Jan 8, 2008 | 09:09 PM
oldpapa1949's Avatar
So, if i start my car now and don't hear the clunking noise I should take it in for repairs because the self check is not working or bad abs.
Now I'm looking at my glass of half filed or is it half empty?
This noise is a normal operation of the ABS System. Do not attempt to repair this condition. Thus if you dont hear it, then attempt to repair?
Hey what can I say, in a hotel and nothing else to do and this was something to do!
Old
Old Jan 8, 2008 | 09:13 PM
blackb13's Avatar
ORIGINAL: oldpapa1949
Perhaps you should turn up your BelTone instead of going to the dealer.
Old Jan 9, 2008 | 08:06 AM
chenarm's Avatar
You would hope that if the selftest fails or doesn't run at all, that you would get a warning! I would just assumethat itis normal but not manditory, it could just be that some batch of parts are noisier than others, without actually being defective. I have never heard the clunk.
Old Jan 10, 2008 | 08:11 AM
ORIGINAL: blackb13
Hehe, its a Siemans digital..
Old Jan 13, 2008 | 11:29 AM
armymen's Avatar
are that probleme is in 08 too ?
Old Jan 13, 2008 | 05:48 PM
tdford's Avatar
ORIGINAL: blackb13
Yep...
Its the ABS sylenoid being activated. It does it once evertime the car is turned on, and is activated around 2-3mph. Just loud parts, dont worry about it...
xyzik
39
Sep 12, 2016 10:25 PM
ruski
Feb 17, 2011 04:01 PM
snookey318
Nov 5, 2009 09:14 AM
kevin
Dec 11, 2007 06:17 PM
sd_outlander
Dec 2, 2007 01:53 PM
