TURN ON FOG LIGHTS W/OUT HEADLIGHTS?
Old Nov 7, 2006 | 08:47 PM
TinkerMan's Avatar
Default TURN ON FOG LIGHTS W/OUT HEADLIGHTS?
Hello all:
Anyone modified their foglight switch so that they can be turned on without having to turn on your headlight first? Seems like it could be a relatively simply fix as long as you know which wires to mess with.
I'm planning to put some yellow 9006 bulbs down there. I think it would look quite sharp instead of the regular boring white bulbs.
- Tinkerman
Old Nov 7, 2006 | 10:32 PM
06OutlanderSE's Avatar
Default RE: TURN ON FOG LIGHTS W/OUT HEADLIGHTS?
If someone knows how to do this i would like to know also.......
Old Nov 7, 2006 | 11:38 PM
arstickerdude's Avatar
Its not hard just splice them into your parking lights.
Old Nov 8, 2006 | 01:41 AM
N/Teclipse's Avatar
Or if you want to put a switch inside just hook them to the battery, lol just make sure you turn them off before you get off the car so as not to run down your battery. I can remember if they are a three or two wire hook, if so one of them will need to be grounded, to find the color code of wire colors, you can try searching online but I believe the manual will tell you, correct me if I am wrong though.
Old Nov 8, 2006 | 12:54 PM
TinkerMan's Avatar
I had a Honda Civic years ago and hooked the aftermarket fogs to the battery. Very easy to forget that they are on after turning off the engine (despite having a light on the lever switch).
Old Nov 21, 2006 | 05:33 PM
lightforce's Avatar
But you can turn on your fog lights when only your parking lights are lit (at least I can with my european-spec outlander 2004)... does it work like that for all versions? it seems the safest solution to avoid running down your battery after parking
Old Nov 21, 2006 | 07:24 PM
my otulander only allows me to turn the fogs on if i have the low beam headlights on first....i wish they would turn on with the parking lights on only
Old Nov 21, 2006 | 10:04 PM
dirtwagon's Avatar
....and they likely turn off when you turn on your high beams too. I got my aftermarket fogs that go on and off whenever I want them too...lol. Thats the bad thing about the factory fog lights- had the same problem on my Trailblazer. Now I buy aftermarkets and I'm always satisfied and save $150
Old Dec 1, 2006 | 01:12 PM
Punisher's Avatar
heh, i bought my factory fogs for $75. I love ebay
Jims M
May 1, 2011 07:52 AM
blueb16
Feb 27, 2011 01:33 PM
Monte98
Dec 8, 2010 01:46 AM
thecrowforever
Apr 14, 2008 02:38 AM
dornstar
May 22, 2006 04:58 PM
