turn signal side markers
Old Mar 26, 2008 | 12:15 PM
klaviermann's Avatar
Default turn signal side markers
can anyone tell me if the side marker of the 07 outlander is one piece? i mean... can i just replace the bulb or i need to replace the whole side marker? any help will be appreciated, i want to replace the amber light with hyperwhite led bulb.
Thanks!
Old Mar 26, 2008 | 02:56 PM
chenarm's Avatar
Default RE: turn signal side markers
I think it's one peace, you should be able to remove it be justt pushing it towards the back of the car, and the front of it should pop clear.
Old Mar 26, 2008 | 04:40 PM
Murray82's Avatar
Guten TagPianoman ,
I actually tried to replace the bulb in mine but it would require a lot of work and still might not be possible. The bulb is actually in a housing and the clear plastic portion covering thebulb is glued to the housing. If you wanted to replace the bulb you would have to find out what kind it is and then unglue the clear plastic cover, then glue it back once the bulb is replaced. It seems like too much of a hassle but if you do it let us know.
Old Mar 26, 2008 | 10:11 PM
i know how to replace it... but i want to replace the amber bulb with a white (led) one... can you guys know where can i find this side markers in clear... or other car's that fit in the hole of the side marker?
Thanke!
beavy09
Apr 20, 2009 01:11 AM
Jabl3s
Feb 1, 2009 06:59 PM
atown420
May 8, 2008 09:36 AM
capecodder
Aug 4, 2007 08:32 PM
dornstar
May 22, 2006 04:58 PM
