Upgrade Window Switches
Old Apr 5, 2011 | 04:23 AM
firstorbit84's Avatar
I was thinking something more along the lines of putting a single recessed LED into the driver's door handle area, and try to angle it to shine out onto the buttons. I haven't really looked into other good spots to hide recessed lights, but I'm sure there are probably a few good places to put it.
Old Apr 5, 2011 | 04:25 AM
The UV lighting would probably freak me out too much when I saw my shoelaces and passengers' teeth glowing too. You might as well consider putting small strips of glow in the dark material on the switches.
Old Apr 6, 2011 | 10:09 AM
gringgo's Avatar
Originally Posted by hotponyshoes
I have a spare set of drivers switch cluster,
When I get 10 mins I will pull it apart and see if the drivers door switch fits other positions.
Let me know about the switches. I will also look into the LED lights. Thanks.
Old Apr 6, 2011 | 04:39 PM
GREG's Avatar
I purchased lights very similar to the ones attached in the link. My purpose is to drill a small hole just below the pop out cup holder on the interior closest to the door jamb for installation. If they produce too much light I plan on trying either electrical tape precisely cut and placed on the light to direct the light path or using black paint to achieve the same result.
http://www.oznium.com/prewired-superflux
http://www.plasmaled.com/5mm8mmled.htm
Old Apr 7, 2011 | 02:40 PM
TROFLEK's Avatar
Hello everybody, look at this link which I found on a German side. Unfortunately the guy did choose blue lighting but further it is just fine. Job well done. Hope you understand German. He drilled some holes, hot-glued in the LED and connected it.
http://www.outlander-forum.de/sogeht...schalter_1.php
Old Apr 7, 2011 | 04:40 PM
GREG's Avatar
Thumbs up
Thanks for sharing the idea. The led is throwing a little too much light at the side door panel. BUT a little touch up of black paint on the LED will tone it down a bit. I like the concept.
Old Apr 8, 2011 | 08:42 AM
gringgo's Avatar
Like the idea and the implementation is well done. I have to agree that too much light is thrown.
blackdampminer
Sep 13, 2023 10:25 AM
knockout509
Aug 14, 2008 06:35 PM
racerx55
1st Generation
Aug 19, 2007 09:37 AM
instaldave
Mar 16, 2007 01:09 PM
franciscopina
Sep 6, 2006 12:01 PM
