USB Configuration
Old May 6, 2011 | 07:02 AM
cooleshal's Avatar
Default USB Configuration
Hi
I have tried without success to connect my iPhone via USB to the SAT Nav unit, Bluetooth works fine but audio quality is not great for music.
I have tested a standard usb stick and am impressed with the quality of sound i can get from the usb. My music is already ripped into high quality flac files which I can easily convert to 320kbs mp3 files for the car (UK 2011 GX4).
Where i need help is with playlists which currently reside on iTunes. Anybody got an idea how to transfer iTunes playlists to a usb stick and any advice on opitmal file structure configuration for a 16GB usb stick would be welcome.
thanks
Paul
Old May 6, 2011 | 10:22 AM
ryandlor's Avatar
I don't think flac files work with most units.
can yo convevrt to mp4?
Old May 6, 2011 | 11:11 AM
Lunatic59's Avatar
Originally Posted by cooleshal
Hi
If you have iOS 4.x it won't work with the current generation of Mitsu radios.
thanks
Paul
As long as you maintain the same folder structure/file names on the flash drive as you have in iTunes, it's easy.
First, on the usb stick, put all your music folders into a folder called "music" (no quotes). Then create a folder called "playlists".
In iTunes, right-click on the playlist and export as an .m3u to the "playlist" folder on the usb stick.
Open the .m3u file on the usb stick with a text editor. Notepad is good enough. I created a sample to show you. The file is called beatles.m3u
Code:
#EXTM3U
#EXTINF:159,Taxman - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\01 Taxman.mp3
#EXTINF:127,Eleanor Rigby - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\02 Eleanor Rigby.mp3
#EXTINF:181,I'm Only Sleeping - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\03 I'm Only Sleeping.mp3
#EXTINF:181,Love You To - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\04 Love You To.mp3
#EXTINF:145,Here, There and Everywhere - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\05 Here, There and Everywhere.mp3
#EXTINF:160,Yellow Submarine - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\06 Yellow Submarine.mp3
#EXTINF:157,She Said She Said - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\07 She Said She Said.mp3
#EXTINF:129,Good Day Sunshine - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\08 Good Day Sunshine.mp3
#EXTINF:121,And Your Bird Can Sing - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\09 And Your Bird Can Sing.mp3
#EXTINF:121,For No One - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\10 For No One.mp3
#EXTINF:135,Doctor Robert - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\11 Doctor Robert.mp3
#EXTINF:149,I Want to Tell You - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\12 I Want to Tell You.mp3
#EXTINF:150,Got to Get You into My Life - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\13 Got to Get You into My Life.mp3
#EXTINF:177,Tomorrow Never Knows - The Beatles
C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music\The Beatles\Revolver [UK]\14 Tomorrow Never Knows.mp3
You want to adjust the paths to the files so press ctrl-H (edit>replace)
Find: "C:\Documents and Settings\<username>\My Documents\My Music\iTunes\iTunes Music"
and replace with "..\music"
What you should end up with is a file that looks like this:
Code:
#EXTM3U
..\music\The Beatles\Revolver [UK]\01 Taxman.mp3
..\music\The Beatles\Revolver [UK]\02 Eleanor Rigby.mp3
..\music\The Beatles\Revolver [UK]\03 I'm Only Sleeping.mp3
..\music\The Beatles\Revolver [UK]\04 Love You To.mp3
..\music\The Beatles\Revolver [UK]\05 Here, There and Everywhere.mp3
..\music\The Beatles\Revolver [UK]\06 Yellow Submarine.mp3
..\music\The Beatles\Revolver [UK]\07 She Said She Said.mp3
..\music\The Beatles\Revolver [UK]\08 Good Day Sunshine.mp3
..\music\The Beatles\Revolver [UK]\09 And Your Bird Can Sing.mp3
..\music\The Beatles\Revolver [UK]\10 For No One.mp3
..\music\The Beatles\Revolver [UK]\11 Doctor Robert.mp3
..\music\The Beatles\Revolver [UK]\12 I Want to Tell You.mp3
..\music\The Beatles\Revolver [UK]\13 Got to Get You into My Life.mp3
..\music\The Beatles\Revolver [UK]\14 Tomorrow Never Knows.mp3
Save and you're done.
Old May 8, 2011 | 11:40 PM
joel_79's Avatar
Is it normal that when I start my car it takes at least 5 minutes to my usb stick be available (usb loading), it is a 16gb with about 1,000 songs in it : ). Is there something that can be done to avoid too much loading/waiting?
Old May 15, 2011 | 08:27 AM
Red Kite's Avatar
It's certainly not instant. If it's 'picking up where it left off' it can take a couple of minutes, if you have swapped source it can take longer. You might also have a slower USB stick.
Old May 20, 2011 | 04:31 PM
blueb16's Avatar
how exactly can you "teach" it to pick up where it left off? my '10 GT used to do it but as i add more mp3 to the 8gb flash drive, it no longer remembers where it left off. if i turn off then turn on my car, the playlist will start from the 1st song on the drive.
Neu4ja
Nov 2, 2014 08:19 PM
spk2000
Jul 15, 2011 09:15 AM
dbblackdiamond
Sep 28, 2010 08:03 AM
EdCoffin
Nov 10, 2009 10:13 AM
p6793026
Sep 23, 2008 02:38 AM
