What are electrical wires beneath seat bases for?
Old Apr 7, 2011 | 05:59 PM
WAB's Avatar
WAB
Default What are electrical wires beneath seat bases for?
hi folks
I'm a newbie to a 2010 Outlander (UK model) and to this forum.
I have manually controlled driver's and passenger's seats, but today I discovered two electrical wires (1 yellow, 1 black) coming from beneath the floor carpet into the bottom of each front seat base.
Any ideas what these might be for?
Mine is the Outlander Juro (special edition) but hasn't got electrically adjustable or heated seats.
Thanks for any suggestions.
Walter
Old Apr 7, 2011 | 06:58 PM
milliesdad's Avatar
My best guess is that the wires are for options that you do not have on your vehicle. Car manufacturers will use one harness with all harnesses haviong oujtlets for all the options. They will not make a complete harness for a car with heated seats and one for non-heated seats. They save money in the long run.
If you wanted to add heated seats or power seats, the wiring is there all ready.
Old Apr 7, 2011 | 08:54 PM
ivanz's Avatar
Heated seats
Power seats
Airbag weight sensor
Old Apr 8, 2011 | 11:50 AM
FiReBReTHa's Avatar
ejector seat option.
Old Apr 11, 2011 | 11:20 AM
STick170's Avatar
Any wiring for the supplementary restraint system (e.g airbags and pre-tensioners) is always yellow in colour if that helps you.
Old Apr 13, 2011 | 07:20 AM
Jimbojangles's Avatar
I think there are also connections for the rockford fosgate amp.
Old Apr 16, 2011 | 12:22 PM
WAB's Avatar
WAB
Default Thanks for suggestions
hi folks
Thanks for the suggestions.
WAB
Old Apr 16, 2011 | 02:45 PM
armymen's Avatar
under the seat if the the eletric seat, even if you dont have any that cable is there in case.
They had a recall on them too, can cause the car to actualy caught on fire because of corrosion because of water and salt from the winter.
I have the 2008 outie, and it was a recall.
Mitsugurl
Jul 22, 2018 08:51 PM
newoutlanderfan
Aug 29, 2011 09:29 AM
DaBearSox
May 8, 2010 08:32 AM
theoh
Nov 9, 2009 05:43 PM
baker_sk8er37
Jan 27, 2005 10:20 PM
