what's that button
Old May 12, 2011 | 01:01 PM
bianchimoon's Avatar
Default what's that button
Hi all, am new to mitsubishi, have an Outlander 09 model and there's a small button just above the 12v outlet ahead of the gear lever, to be honest didn't even see it in the gloom down there, but pushed it and it flashed red. Can anybody help with what it is/does? - thanks in a advance alan
Old May 12, 2011 | 03:29 PM
STick170's Avatar
Hi Alan, it sounds to me like it's the alarm button that you're refering to. Is yours a UK vehicle? I believe the UK ones have a Cobra alarm fitted at the time of import.
Old May 13, 2011 | 02:54 AM
Thanks STick, it is a UK vehicle guess then, that pressing it is just to test it's working? it just flashes for a second or so after pressing?
Old May 13, 2011 | 03:39 AM
Wunnunda's Avatar
Just a guess but most cars have a button to switch off the internal volumetric sensors while still allowing the deadlocks to function. Allows you to leave dogs etc in the car without triggering the alarm. Has to be pressed once everytime you operate the system IIRC.
Old May 14, 2011 | 12:09 PM
STick170's Avatar
Wunnunda is correct, If you press and hold the button twice (it'll do one really short blink and then a longer blink each time you press) you will disable the interior sensors until the next time you unlock. This is quite a handy tip because the manuals were incorrectly written on some models (including mine) and the interior sensors can be far too sensitive (also including mine!)
Old May 16, 2011 | 11:05 AM
thanks Wunnada and STick, appreciate the help with tha - cheers
Number6
Aug 1, 2007 04:58 PM
blamesociety
Jan 17, 2007 09:11 PM
trident
Jan 12, 2007 06:03 PM
silvercoupe97
Dec 1, 2006 09:09 AM
ncyankeealva
Apr 5, 2006 11:34 PM
