Winter tires for 2016 outlander
Old Nov 8, 2016 | 12:33 PM
Tib_mastiff's Avatar
Originally Posted by Kip
+1 on the Nokian all weather 4 season winter rated tires. U can run them all year and never have to worry about it. I just put a set of 4 on my Mitsu. Cost was $900 cdn all in.
Where did you get it from? Is $900.00 including steel rims?
Old Nov 8, 2016 | 06:51 PM
Kip's Avatar
Kip
Kal Tire (I get a discount through a work promo which I probably should have mentioned)
No change on the rims. I run the alloy all year too. If you are switching out to steel rim then you may as well just buy separate tires for them imo. I live on the west coast so rain is my main enemy (very little salt on the roads here) but anytime I go up in elevation there is snow.
Old Nov 13, 2016 | 02:47 AM
catacami's Avatar
Wink 225/65/R16 Toyo Observe GSI 5 & 16" Fast Orbit Winter Aluminum Alloy Wheels
Just installed today from 1010TIRES.COM Tires and Wheels Online Authority
With special offers $80 INSTANT REBATE WITH WINTER/ALL-WEATHER TIRE & WHEEL PACKAGE Special Offers | 1010Tires.com
Plus $70 Toyo Fall 2016 Rebate from Toyo website
Total: 1,647 Canadian Dollars
Attached Thumbnails Winter tires for 2016 outlander-20161112_160106_1479020676342.jpg   Winter tires for 2016 outlander-20161112_160121_1479020676782.jpg   Winter tires for 2016 outlander-tire1.png   Winter tires for 2016 outlander-20161118_024423.jpg
Old Nov 13, 2016 | 11:45 AM
The Silent Seed's Avatar
You went down 2 inches in size ?
Old Nov 13, 2016 | 10:29 PM
catacami's Avatar
Yes. Why choose a smaller size for winter? please read this article > Winter Tech Information - Size Selection of Winter / Snow Tires
Old Nov 13, 2016 | 11:51 PM
Krakker's Avatar
No big issue going smaller wheels, as long as the overall tire height is close to stock you'll be fine. Even a small difference in larger overall height is OK.
I ran 17's on my Sonata SE turbo with a 215 width VS the stock 225.
I also ran more offset to put the wheel/tire combo flush with the fender for a better track width. (more stability) That car was a champ running full on snow tires, and the smaller wheel meant more tire to absorb the crappy bumps from packed snow or ice.
The 17's were as small as I could go on the SE due to suspension components, otherwise I would have gone 16's.
My summer combo is a set of 19's with 245 wide sport tires. since this is an all wheel drive vehicle, I'm going to be using the stock tires for fall / winter till they are gone, then I'll go with aftermarket wheels and narrower snow tires.
Old Nov 14, 2016 | 09:00 AM
Cool read - and thanks for the input guys.
Old Nov 14, 2016 | 03:36 PM
Fooken eh's Avatar
Use a all terrain tire or truck tire....I'm running 225/70 16 cooper at3( w 8mm spacer just in case)looks bad *** too
I'm in Halifax too I know a east coast winter...wanted a taller more agressive tire for Nova Scotia winters
Here's the fit
215/70 16s is factory which is bs Imo lol gonna run 16s go bigger no rub it's an inch taller tire ish and only half inch wider but major difference...keep in mind tho 60mph on the dash is actually 64 with this tire size
Old Nov 14, 2016 | 04:31 PM
16's is factory ??? Is that for "Canadian models" ? Mine (and most) came with 18's.
Very happy with the 18's. Wouldn't want to mess with the speedo / odometer by playing with different tire sizes, etc.
Old Nov 14, 2016 | 06:39 PM
nabwong's Avatar
The speedometer doesn't change much. You can do a tire calculator and they'll show you how much your speed decreases or increases with alternative tire sizes. It's could all be within 1-2%
