Winterising and Outlander and advice on snow chains
Old May 16, 2011 | 02:13 AM
bccj1's Avatar
Default Winterising and Outlander and advice on snow chains
Hi gang,
With the first icy blast of the year heading our way here in Kiwiland, my thoughts turn to ski trips later in the year. I would therefore be grateful for any advice regarding winterising an Outlander for trips up icy mountain roads in conditions below 0C. As a 2007 Mitsubishi Outlander VRX, it can switch between 2WD, AWD and 4WD lock but as a 'softroader' with no low range and normal road tyres, I'm not sure how capable it will be in such conditions and whether I will also need snow chains just in case. If so, can I get away with a single set of chains for the front wheels (in 2WD or AWD) or will I need a second set for the rear wheels as well? And can anyone recommend a brand of reliable, easy-to-fit chains for 225 55 R18 tyres? I'd be grateful for your experience and advice.
Thanks for your help.
Old May 26, 2011 | 04:36 PM
Sleddog's Avatar
Hi mate .
In OZ I would say you would be fine with road tyres and 4wd.
But knowing about the Kiwi roads up the moutain and seeing this video ,I thought I would post it ,so the guys that drive in snow alot in the USA etc ,can see what you up against ,like the drop offs and a dirt track when they give some advice.
I ski alot and brought a 2WD as its not every day that a 2WD can't get up to our resorts with out chains needed as its tar all the way and will buy some quick fitting Rud matic snow chains.
http://www.youtube.com/watch?v=4IBek...eature=related
Old May 27, 2011 | 02:01 PM
Bomber's Avatar
Hi, i have the same spec as you and have just gone through two of the worst winters on record and road tyres are no good on steep slopes . can recommend Pewag Snox Pro .chains, on front wheels only will give you plenty of grip
torihada
Nov 26, 2012 01:23 AM
Fill
Aug 28, 2011 02:31 PM
Trailrunner
Mar 27, 2009 01:31 PM
dorian7
Nov 12, 2007 11:06 PM
wymanc
Feb 14, 2007 12:28 AM
