wiring colour code
RE: wiring colour code
Easiest way to do it is to buy a wire hareness. The harnes will plug into your stock plug and then simply wire the harness wires to the head unit wires. The harness is labeled as well as the wires on the head unit.
If you have the premium Infinity sound system you will have to bypass the factory amp located under the drivers seat. If you are not that experianced with audio you may want to take it to a car audio shop. I did mine but I didnt think to write down the colors as I found them.
https://mitsubishiforum.com/m_26281/..._/tm.htm#33193
Here is my previous post on the subject. Not a color guide but directions on how to find them yourself.
Look up your stereo model or brand in crutchfield.com and order the wire harness and vehicle master sheet.
http://www.crutchfield.com
Let us know if you have any luck with it. I have ordered mounting brackets for my pioneer speakers from crutchfield. Their customer service is top notch.
