wiring colour code
Old Mar 18, 2007 | 08:05 AM
outlander 2003's Avatar
Default wiring colour code
hello all,
i was just trying to install a new head unit in my 2003 outlander and i was wondering if anybody here knew the colour codes for the wiring
need help urgently
thanks
kevin
Old Mar 18, 2007 | 12:07 PM
antlip's Avatar
Default RE: wiring colour code
Easiest way to do it is to buy a wire hareness. The harnes will plug into your stock plug and then simply wire the harness wires to the head unit wires. The harness is labeled as well as the wires on the head unit.
Old Mar 20, 2007 | 06:45 PM
mld211's Avatar
If you have the premium Infinity sound system you will have to bypass the factory amp located under the drivers seat. If you are not that experianced with audio you may want to take it to a car audio shop. I did mine but I didnt think to write down the colors as I found them.
Old Mar 20, 2007 | 07:51 PM
JMC's Avatar
JMC
Yeah...make sure you bypass the factory amp. There was a color code on here once. Maybe do a search?
Old Mar 25, 2007 | 01:57 PM
mld211's Avatar
https://mitsubishiforum.com/m_26281/..._/tm.htm#33193
Here is my previous post on the subject. Not a color guide but directions on how to find them yourself.
Old Mar 25, 2007 | 08:28 PM
fba0861's Avatar
Look up your stereo model or brand in crutchfield.com and order the wire harness and vehicle master sheet.
http://www.crutchfield.com
Let us know if you have any luck with it. I have ordered mounting brackets for my pioneer speakers from crutchfield. Their customer service is top notch.
Wreck
Jul 22, 2013 12:59 AM
rdenis
Jul 4, 2007 02:23 PM
BrianB
Jun 25, 2007 10:07 AM
BrianB
Apr 2, 2007 01:55 PM
outlander 2003
Mar 18, 2007 03:46 PM
