would these wheels fit?
Old Jan 28, 2013 | 02:15 PM
CMS062407's Avatar
Default would these wheels fit?
Hey all,
I am wondering if these wheels would fit?
They are 2011 mazdaspeed 3 oem wheels...
All the specs are the same as the outlander....e.x the bore, lug nut
Only difference is the offset of the mazda wheels are +52
Would they sit flush? Or close to flush?
Thanks!
Old Jan 29, 2013 | 12:44 AM
Burtonrider10022's Avatar
A larger offset isn't a terrible thing. Smaller and you'd risk caliper rubbing issues.
What is the bore & lug nut differences? Instead of just saying what is different how about you list the full specs for both your model, year, and country (since you didn't put your location in your profile) and the specs of the mazda wheels you're looking at.
Old Jan 29, 2013 | 08:43 AM
CMS062407's Avatar
I said all the specs are the same....except for offset.
Old Jan 29, 2013 | 08:47 AM
CMS062407's Avatar
Old Jan 29, 2013 | 02:40 PM
It looked like "ex hub bore, lug nut" meant except hub bore, lug nut.
You should be fine with those rims, if worse comes to worse you might need a 10mm spacer.
Old Jan 29, 2013 | 03:08 PM
CMS062407's Avatar
hmm okey dokey....so i just need to find a set of 10mm wheel spaces that are 5x114.3 and 67.1 hub center bore? and then any set of wheel spacers will work?
p.s.
these are the wheels I am talking about, I think they would look very sporty on my 2011 xls.
2011 Mazda Speed 18" Rims
Old Jan 29, 2013 | 08:32 PM
You might not need any spacers. If it were me, I'd locate spacers online, but not order them. Get the rims and test fit them, then, if you need the spacers order them.
Our lug pattern and hub bore is the most common in the US and lots of cars use this pattern so finding spacers shouldn't be a problem
ryandlor
Nov 5, 2009 08:52 AM
someguy1984
Feb 7, 2009 04:08 PM
95gtsl
Apr 30, 2007 08:19 PM
95gtsl
Mar 15, 2007 01:37 AM
viper94311
Nov 2, 2005 10:50 PM
