fuel relay ground
Old Aug 4, 2013 | 03:11 PM
Brian Creel's Avatar
Default fuel relay ground
2000 montero sport with no ground to fuel pump relay. Is there an interlock associated with this ground?
Old Aug 4, 2013 | 10:46 PM
Akzle's Avatar
don't know. is it inter-locking you out? or are you just curious?
Old Aug 4, 2013 | 11:39 PM
without a ground on the relay coil the relay doesnt close so the pump doesnt come on. the ground is switched in the computer somehow so i thought it may be some sort of interlock.
Old Aug 5, 2013 | 06:27 AM
Jeff Collision's Avatar
You have both a fuel pump relay and a module in this vehicle to be concerned with, the relay powers and the module; the module passing current and ground to the pump. The relay is mounted in the passenger side foot well area, behind the carpet of the center console just below the radio area. It is attached to the MFI relay as a paired unit.
Old Aug 5, 2013 | 01:45 PM
Akzle's Avatar
oh right.
My guess is its a negative trigger relay, so the comp sends negative signal to trip it.
Could be bypassed easy enough.
Old Aug 5, 2013 | 04:00 PM
what would keep the ground circuit from being completed? would it be safe to bypass?
Old Aug 5, 2013 | 08:28 PM
Akzle's Avatar
a relay is GENERALLY on the positive side of the circuit. It uses a negative signal/trigger of low current, to switch the positive high current.
By grounding out the negative trigger, the relay is always 'switched on'
Google "how does a relay work"
Old Aug 5, 2013 | 08:38 PM
i know how a relay works im wanting to know why the ground is not switched on. theres got to be a reason for this. is it an interlock that is working properly and keeping it from working to protect the engine or is it supposed to be working? i can ground the relay coil and the pump runs and the engine runs until i remove the jumper then it quits. should i just ground it and go on or is that a bad idea?
Old Aug 6, 2013 | 01:48 AM
Akzle's Avatar
id probably hook it up to an 'on' circuit, so only runs when the key is on.
Check the unit that is supposed to be sending the negative trigger (module, pc?), sounds like thats whats faulty. Kinda like where we were in post #3.
Old Apr 4, 2018 | 01:24 PM
Laura Compion Jackson's Avatar
where is this located and how do I find an on circuit to ground it to?
jtdurett
Apr 4, 2018 01:20 PM
nstriglia
1st Generation
Mar 2, 2006 01:33 PM
rahlquist
1st Generation
44
Aug 3, 2005 05:10 PM
hoosierdadi
Jan 24, 2004 12:05 PM
audionxs
Sep 19, 2003 11:56 PM
