Ignition Timing for 4G32 Engine
Old Feb 11, 2014 | 04:54 PM
California's Avatar
Default Ignition Timing for 4G32 Engine
Does any body know the initial ignition timing for the 4g32 SOHC engine? I have it set for 5 BTDC but the intake vacuum is very low. Only 16" hg.
Old Feb 12, 2014 | 12:21 PM
Akzle's Avatar
depends on your locale. Should be a veci label on firewall/bonnet/sills that'll tell you.
Either need to smog tune it or road test and tune. Up to 8btdc should be fine.
Old Feb 12, 2014 | 04:55 PM
California's Avatar
Default Thanks!
Many Thanks for the information. My location is in the Philippines and the car is a Lancer 1987, Model A174A. I am going to advance it to 8 BTDC as you advise. Hopefully this will increase the gas mileage. They still sale Super leaded gasoline so I don't have to worry about Pinging. Thanks again.
Old Feb 12, 2014 | 05:49 PM
Akzle's Avatar
bear in mind your timing is only the initial advance. After that vacuum/sprins and weights come into play.
Things that affect it are altitude and climate.
Check out Ignition Timing
Old Feb 19, 2014 | 01:22 AM
California's Avatar
Default Total ignition advance
What is the total ignition advance of this engine 32 degrees at 4000 rpm?
crazylegs
Oct 2, 2013 07:51 AM
rgs944
Oct 1, 2013 03:50 PM
PharmD
Nov 9, 2011 11:02 AM
ZVNJ
Jun 22, 2010 09:35 AM
mxer1
Feb 3, 2007 04:41 AM
