new guy with problem plz HELP
Old Aug 24, 2013 | 09:31 AM
shadowfiree's Avatar
Default new guy with problem plz HELP
I have a 1992 mit. Montero sr 3.0L 4WD... Did oil change/ tune up / new fuel filter/ new pvc valve. The problem is it takes me from a cold start of anywhere from 6 or more hours sitting 3-6 tries to start Montero. But once I start the Montero and it gets started I can get in and out all day with a 1-3 try start with no problem. No I haven't tested fuel pump need special adapter. did a crude way of testing by turning key and trying to start it and I put a rubber hose on gas line and put my thump over hose to see if pressure stayed and it did. Now I turned the key to see if gas comes out when I just only turn the key but not trying to start it and no gas came out of hose... there's a test point for this action, so I tested it with current from battery and it came right out of the hose like it was suppose to do when u turn the ignition but not to start it. OK... NOW I need anyone who has had this problem and to plz give me some answers that could help me... i'am hoping maybe fuel pump relay/ fuses/ something maybe simply like that.... I know it may not be but that's how I feel it runs so great other than that to be sooo old. thanks
Old Aug 30, 2013 | 02:23 PM
Akzle's Avatar
intermittent problem with contacts in the ignition barrel.
or. relay not actuating when in the crank/start position. either way, electrical, somewhere near the key.
Old Jul 12, 2018 | 12:30 PM
Medina Ricardo's Avatar
hi have the same problem every morning whit my 1992 Monty RS cant remember in what page a read that the fuel pump relay behind the globe compartment is the one that's making this problem
Victoria Chapman
May 22, 2012 11:04 PM
eclipselaxr18
Oct 2, 2009 06:36 AM
$manager
Jan 30, 2008 08:02 AM
adinator
Jul 1, 2007 01:44 PM
linkin
Apr 22, 2005 02:29 PM
