actuator solenoid
Old May 9, 2007 | 10:40 AM
Default RE: actuator solenoid
thats what i think. Is he meant the BCS. Because the actuator is just that. Its only called a wastegate actuator. You dont call it a solenoid. But the Boost Control Solenoid can get stuck cuasing you to not build boost. And the Boost controller doesnt come with one. It replaces it. So you can get either an Electronic BC like the greddy profec-b or you can get a Manual BC which are alot cheap and actually more accurate but more dependant on weather
Old May 9, 2007 | 03:38 PM
spyder4g63t's Avatar
so getting a bc will eliminate my performance problems since it replaces it as you said...does the manual bc also replace it...
Old May 9, 2007 | 03:43 PM
yup a manual boost controller will replace it as well. Because all the BCS is, is a stock boost controller. So any aftermarket one will get rid of the BCS
Old May 9, 2007 | 03:45 PM
nice what brand do you recomend...
Old May 11, 2007 | 03:20 PM
50ul }{4ck3r's Avatar
I use the TurboXS Conversion Boost Controler...flip of a switch gives u more boost
agallardo
Feb 25, 2007 03:56 AM
agallardo
Feb 24, 2007 12:41 AM
jerusry
Jan 2, 2007 11:36 PM
Missile
Nov 26, 2006 10:54 PM
devildicer
Aug 13, 2004 02:39 AM
