cheaper place to get this
Old Jul 10, 2008 | 01:35 PM
9eclipse8's Avatar
Default cheaper place to get this
hey guys, im looking to turbo my 420a, and am told that the hahn racecraft turbo kit is the best one to get, now i heard from a friend that there is a website that sells it for a little bit cheaper, is this true? and whats the website?
Thanks
Old Jul 11, 2008 | 07:12 AM
Default RE: cheaper place to get this
http://www.turbokits.com/eclipse_turbo_kits.html
However...make sure you have done your research and realize you are going to spend alot of money for a mediocre gain. Because you are probably only looking at about 200hp which is right around the stock hp for a gst. And also realize that these "kits" still do not include everything that you will need to run them such as any gauges you need, boost controllers, tuning devices. Turboback exhaust that will be nesessary.
Not to mention you are now going to be putting alot more stress on a motor that was not meant to handle it. You will only be able to run about 6-8psi on the stock block, and i guarentee within a year your head gasket will be blown from the extra pressure. So be prepared to replace that.
All im saying is make sure you do your homework first before you jump into anything and be prepared to spend some money
hadesr
Jul 25, 2008 05:30 AM
sircrxracer
Sep 11, 2007 09:26 AM
GSXEX Knubbe
Apr 13, 2007 07:50 PM
dansevo
Sep 1, 2005 09:52 AM
