clutch??
Old May 21, 2007 | 08:39 PM
spyder4g63t's Avatar
Default clutch??
something is bad here..my shifting is ruff i grind third...and when im in gear i can still take it out of gear without pressin in my clutch...wierd...need info is it serious????again i was acceleratin fast hittin boost and like @ 5000rpm maybe....i hit the brick wall and te loud pop sound...then my check engine light came on...
Old May 21, 2007 | 09:00 PM
silvercoupe97's Avatar
Default RE: clutch??
Have you played with the clutch rod that's connected to your clutch pedal and master cylinder yet?
You should be able to get out of gear from 3-5 (I think it was, maybe just 3&4). 1&2, you should have to press the clutch in. Mine does it and thought it was weird too, but my clutch only has ~4k on it with new Redline fluid. Other DSMs out here do it too...odd, I know.
Have you checked your fluid level? Does it have metal shavings? What have you done so far?
Old May 21, 2007 | 09:39 PM
well i changed my fluid looks good to the eye,,,i put a fidanza clutch and flywheel...but the instruction manual that came with the flywheel said to use only 95 model hardware dont know why u think that could have something to do wit it you think it could be a bad synchro in third...or maybe the master cylinder how could i check with out paying a costly mechanic....any info on the sputtering poor performance loud pop wall hitting maybe fuel cuttin dsm...
Old May 22, 2007 | 05:34 PM
and also when i push my clutch in it makes kinda like a humming noise..like when u have no power steering fluid
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
