compression test/boost test
Old Oct 12, 2006 | 11:56 AM
ryant25bb's Avatar
Default compression test/boost test
I prev did a compression test first to see if any of my cyl were loosing pressure and they read 185/190 psi across the board. Although i tested while the car was cold while some people say to do it while it has been warmed up. Does anyone now if it really matters/because since the readings were so good i didn't bother warming the car up. Also can u connect a boost leak tester up to you intake manafold to check for leaks if you dont find any i the intercooler piping. I heard you can but i just wanna be safe. thanks
Old Oct 12, 2006 | 12:47 PM
Default RE: compression test/boost test
yea you can get a boost leak tester and test it by hooking it up to the intake.
And yes you want the engine to be warm because you want to make sure that the oil has been warmed up otherwise your results wont be correct. The test wont work correctly. Id check them again to be positive.
Old Oct 12, 2006 | 12:54 PM
ryant25bb's Avatar
thanks
bossgrabber
Mar 4, 2009 06:21 AM
newguy2007
Mar 15, 2008 05:34 PM
grim0reaper0
Aug 27, 2007 11:37 PM
Drew
Jun 22, 2007 12:29 PM
xsoldier06
Feb 2, 2007 02:17 PM
