crack in manifold
Old Jan 28, 2007 | 04:45 PM
spyder4g63t's Avatar
Default crack in manifold
this is tha crack
[IMG]local://upfiles/9248/40046525F2CA42C6A9894B599D4B4845.jpg[/IMG]
[IMG]local://upfiles/9248/4957634C734849DBA4CCE68F7FC733BF.jpg[/IMG]
[IMG]local://upfiles/9248/9BF7896BCD7F40D2A41777E31673FF7F.jpg[/IMG]
Old Jan 28, 2007 | 04:48 PM
Default RE: crack in manifold
full shot
[IMG]local://upfiles/9248/F0489E49752C4E6D9F94CE77EE4D32FB.jpg[/IMG]
Old Jan 28, 2007 | 08:19 PM
silvercoupe97's Avatar
That's a crack alright, lol, but what I don't see is black soot seeping from it. Black soot on the exhaust tract is a tell tale sign of a leak, but there isn't any there.
Can you hear it leaking right there? If not, that's just an external crack that will eventually lead to it leak exhaust.
Is it me or is that crack going up to the bolt?
Old Jan 29, 2007 | 10:07 AM
Is that just the heat sheild? I cant really tell from the picture
Old Jan 29, 2007 | 10:43 AM
ORIGINAL: TheEngineer
Nope, that's the exhaust manifold.
Old Jan 29, 2007 | 11:18 AM
oh ok so those bolts are where the heat sheild would normally bolt into. I get it
Old Jan 29, 2007 | 02:12 PM
so can that crack be the cause of my performance problems..today again i was in 4th pushing it to 5500 rpm and bam a loud pop then my check engine light came on...it came on before then i went to see what it was and they said it was o2 sensor can that cause major problems?please im tired of not being able to push my car past 4000rpm....so waht should i do...it cant be plugs..wires..maybe injectors??or fuel filter???or pump how can i tell..
Old Jan 29, 2007 | 05:14 PM
I dont remember if you already gave us these, but do you have the codes from the CEL
Old Jan 30, 2007 | 10:29 PM
it was a o2 sensor last time i cheked but ill get another one incase
Pooley
Aug 20, 2010 09:35 AM
2nd g eclipse gst
Aug 27, 2006 02:07 AM
nemo0405
May 19, 2006 04:13 AM
elecbluegst
Feb 9, 2006 03:57 PM
djsmear
May 11, 2004 01:54 AM
