EBC's?
All depends what you want. If you want to be able to change the boost from inside the car and dont mind spending over 300 bucks then the EBC is for you... if you dont want to spend that much and dont mind going under the hood to change it... then the MBC is for you.
I'f you know how too, i suggest you make one, with parts from your local hardware store. I enjoy the lazyness of having not to pop the hood, but manual boost controllers are just way safer, and more reassuring.
But that's my suggestion.
Good Luck
Gus
Good Luck
Gus
ORIGINAL: Malachi
I guess I don't understand why you wouldn't want the most boost you could get all the time. Why would you want your car to be slower then it could be?
https://mitsubishiforum.com/m_42371/tm.htm
https://mitsubishiforum.com/m_69073/tm.htm
https://mitsubishiforum.com/m_125438/tm.htm
https://mitsubishiforum.com/m_124880/tm.htm
Need more materail let us know... or if you got questions just ask
So is there a set psi that I should set it to? If there is, why wouldI want an EBC? . . . Sorry about all the newbie questions, I'm just trying to figure all this out. I can't seem to find any good info anywhere else.
ORIGINAL: Malachi
