EVO III big 16g swap?
Old Sep 20, 2008 | 05:47 PM
98TSi awd's Avatar
Default EVO III big 16g swap?
i own a 98 talon tsi and i was planning on swapping the stock t25 with the big 16g and getting a FMIC but i was wondering if the oil feed/return lines and injectors would need to be swapped as well...if so what are the my best options for performance thanks
Old Sep 20, 2008 | 07:05 PM
dsm1990gsx's Avatar
Default RE: EVO III big 16g swap?
Your gonna need a 2g install kit w/ the 16g turbo and for injectors you can leave the stock injectors in as long as your running stock boost levels.
Old Sep 20, 2008 | 07:30 PM
98TSi awd's Avatar
ok thanks...so i wanna run more psi than stock so i would need to change the injectors for sure then?
Old Sep 20, 2008 | 08:24 PM
silvercoupe97's Avatar
Check the Eclipse FAQ section. I have a whole thread on fuel and the E316G and no, don't run higher pressures with that turbo without the proper supporting mods or you'll be SOL.
Old Sep 21, 2008 | 12:15 PM
98TSi awd's Avatar
oh ok thanks i appreciate it
get435
Mar 17, 2011 04:33 PM
burnmyeyes
Dec 14, 2006 12:08 AM
paintballproam
Sep 13, 2006 10:18 PM
Sebba
Jun 4, 2006 10:30 PM
paintballproam
1st Generation
Apr 17, 2006 08:27 PM
