My turbo fills with boost too fast?
Old May 1, 2013 | 01:58 PM
New Guy's Avatar
Default My turbo fills with boost too fast?
I drive a 1997 mitsubishi eclipse spyder gst automatc 4wd. When I bought the car about a month ago the boost was great, good on take off okay at higher speeds but now, it doesnt work so well. off the line take off is okay if I dont give it alot of gas but if I do, the boost shoots straight up and the car takes off with more motor(turbo feels like it wants to go but doesnt.) then the quick acceleration from the turbo. What im trying to say is when I give it more gas the turbo sucks! Possible problems?
Old May 1, 2013 | 02:17 PM
Sorry, they didn't make the AWD Spyder. I hope you didn't get conned.
I see no problem described here. You ARE using premium fuel, right?
Old May 2, 2013 | 10:28 AM
New Guy's Avatar
Oh well yeah it said Awd in the onwers manual but yeah I run premium gas only. Do you think it could be from too much or not enough oil? When I bought the car it had a valve cover leak so the guy just kept putting oil in when it got too low. When I check it (after starting the car and letting it run a little) the oil level is over where it should be on the dipstick but low on my oil gauge.
Old May 2, 2013 | 10:30 AM
The oil gauge is oil pressure, not level. You should check your oil level with the car not running, and on even ground.
There is NO problem here.
Old May 2, 2013 | 10:44 AM
New Guy's Avatar
Default Sebba
Okay ill check it with it off, thanks for the info there is one more issue with the car, when im driving after the turbo spools I sometimes get back fire from the exhaust and when reving in neutral get a strong smell of gas, possible problems and fixs?
Old May 2, 2013 | 01:05 PM
Please take & post a picture of your engine bay so that I can confirm my suspicions.
Old May 9, 2013 | 04:10 PM
New Guy's Avatar
Hey Sebba sorry I never got a pic of my engine bay but I found out why it feels so powerful then doesnt.
I bought a boost gauge then installed and it showed that my boost is peaking 20psi then drops down to about 10psi, any idea as to why it would do that?
Old May 9, 2013 | 04:12 PM
YIKES. You need to control that boost spike, or else you could be hurting things.
Do you have a manual boost controller on the car? Make sure it never goes over 15psi, or else you're likely doing damage.
Old May 9, 2013 | 06:12 PM
New Guy's Avatar
No im going to order the boost controller and hard intercooler piping to stablize the boost
spyder4g63t
Jun 26, 2007 04:16 PM
locoal619
Feb 6, 2007 11:52 PM
tobyfan
Jul 31, 2006 04:59 PM
duwacker16
Oct 19, 2005 12:14 AM
ram
1st Generation
Jun 12, 2005 12:02 PM
