squealing belts
Old Jan 4, 2008 | 12:58 PM
spyder4g63t's Avatar
Default squealing belts
ocurrs when i start my car in the morning..loud squealing also as i drive off it gets louder..new belts?loose?belt dressing
Old Jan 4, 2008 | 06:57 PM
Rob's Avatar
Rob
Default RE: squealing belts
Dry pully bearings.
Old Jan 5, 2008 | 08:30 AM
TheAdvocate's Avatar
Best thing is to check the belts and see if the grooves are in good shape on them.. If there not then its just a belt..
Old Jan 5, 2008 | 07:48 PM
lhausi2's Avatar
Don't use belt dressing, cuz even if it fixes the problem for the time it'll end up drying the belts up. I would just try and just change the belts, cuz that's usually wut it is
Old Jan 5, 2008 | 10:10 PM
tjbiker031's Avatar
yea 75% of the time its the belts are going bad. usually if the belts arnt bad the bearings on one of the pullies are bad. and like lhausi said, NEVER USE BELT DRESSING! your just temp. fixing the problem, and it will break or give out at a time you dont need it. trust me, i know it happended to me. i had a belt apperently shread on the way to the naval base and it was my ALT belt and made my engine overheat with no power to anything, just bearly keeping the engine running on what i had left on my battery.
moral of the story, fix your dsm, dont do quick fixes
Old Jan 6, 2008 | 05:52 PM
dsm1990gsx's Avatar
Like what everyone else said, change those belts and you should be good to go!
Old Jan 14, 2008 | 02:30 PM
98eclpsrider's Avatar
also check the tension of the belts too my car was squeeling and i new my belts were new, so i checked the tension of all the belts and it was the air conditioning belt that was hella loose.
phils06gt
Apr 18, 2012 12:10 PM
Frustrated
Jun 14, 2009 08:33 AM
anthony_piaa
Apr 1, 2007 11:43 PM
Wagoner
Feb 3, 2007 12:41 PM
00GalantMan
Feb 6, 2006 01:31 AM
