upgrade
Old Mar 22, 2005 | 02:19 AM
baker_sk8er37's Avatar
Default upgrade
if i upgrade to a 20g with a Greddy front mount what size injectors would i need and fuel pump?
also what other types of mods do u think would be needed other than timing belt water pump, balance shaft, plugs and wires
im getting my greddy profec b and my apex super afc
how much torque and ponies do u think i woud be runnin with this turbo??
Old Mar 22, 2005 | 08:35 PM
DSMTalonAWD51's Avatar
Default RE: upgrade
20g is a serious turbo and the biggest most dsm'ers need, it'l take you into 10's. for that turbo besides the stuff you have already listed ( and im assuming you have 3" turboback exhaust and all the basics) you are going to want to run an external wastegate ( ive seen some websites that say they designed an internal wastegate for the 20g, i woudnt trust those) 660cc injectors and a 255lph fuel pump, which means youre also going to need a new fpr. 550's are probly too small for a 20g, but 660's will be fine for running 11's. the 20g can give you easily 400-450 hp to the wheels but you wouldnt want to go any higher than that with stock internals, and your also going to want a good datalogger to tune your safc because you are going to be making a lot of power and half-assing your tuning could be very dangerous.
Old Mar 23, 2005 | 03:19 PM
nate5023's Avatar
Default RE: upgrade
If you want to run over 20 PSI daily you'll need stronger internals.
Old Jul 18, 2005 | 09:32 PM
JDMVR43000's Avatar
Default RE: upgrade
Yep, pistons,c. rods, and sleeving
Old Jul 29, 2005 | 01:56 AM
Default RE: upgrade
i think the only thing to worry about with a 20g at 20psi is the head gasket. just get some arp head studs. i know several people who have run 23-25psi daily on 20g's with 150k miles and stock internals no problems
ListenersAudio
Feb 22, 2004 06:12 PM
fizz111
Jan 27, 2004 02:12 PM
Miic
Jan 11, 2004 11:42 PM
Topspin800
Nov 16, 2003 12:32 AM
Mrfirefox
Jul 10, 2003 06:14 PM
