rhd and gsx conversion
Old May 23, 2011 | 08:11 PM
96_gstspyder's Avatar
Default rhd and gsx conversion
I have a 96 gst spyder and i want to do a rhd and a gsx conversion to it. if anyone has any info for it it would really help
Old May 24, 2011 | 07:29 AM
be prepared to spend ALOT of money in order to do this. Its not a simple bolt on mod. Here is a small list of the important parts in order to do the swap from GST to AWD
AWD Tranny & Transfer Case
AWD Flywheel & AWD Flywheel backing plate
AWD Front axle Assy's
Complete Driveshaft Assy including the bearings and nuts and bolts
Fuel tank assy with the complete filler neck assy
Rear Suspension Assy with all nuts and bolts
Complete exhaust system from an AWD (DP, Cat, Cat back exhaust)
basically you need a GSX donor car in order to complete the swap. And i wouldnt even bother with the RHD conversion. I dont think you understand the ammount of work that would take.
Old May 27, 2011 | 03:04 PM
Revv10K's Avatar
Easier solution for you, move to Canada and import a RHD GSX. It will save you a ton of headaches and cash.
MagicMikeZ32
Sep 23, 2014 09:53 AM
Swizz83
Mar 15, 2014 05:15 PM
right hand drive evo
Jun 5, 2007 10:21 PM
xplhavoc
Dec 28, 2005 11:43 PM
BurntGSX
May 11, 2004 08:54 PM
