1989 Galant GDI no start
Old Dec 25, 2013 | 02:57 PM
anjenoir's Avatar
Angry 1989 Galant GDI no start
Hi Guys,Happy Chrismass to all, my car wont start It has good spark, intank fuel pump works fine, the pressure pump behind the cylinder head delivers fuel to the rail, I checked injector current I got 5 Volts on one of the connector pins, a ground and signal on the other pins, the engine cranks but does not start please help. thank you.
Old Dec 25, 2013 | 04:23 PM
Akzle's Avatar
timing or compression.
Old Dec 26, 2013 | 02:45 AM
anjenoir's Avatar
Angry 1989 Galant GDI no Start
I forgot to mention that the Engine starts if you spray a choke cleaner in the throttle body and dies when you stop spraying I think it is not a timing or compression issue if am not wrong.
Old Dec 26, 2013 | 02:58 AM
Akzle's Avatar
air fuel mix. And timing. And check your plugs again.
Harv
Feb 24, 2013 08:36 AM
coolbreeze61
May 5, 2012 04:26 PM
3s0upy2
Feb 25, 2009 10:17 PM
FREDDIESGALANT
Feb 6, 2007 07:10 PM
Hephaestus
Jan 31, 2006 02:08 PM
