Used Montero Sport Computer Module
Old Dec 28, 2013 | 05:36 PM
johneric's Avatar
Default Used Montero Sport Computer Module
my montero sport won't get ignition. just had the timing belt replace and a few other electrical modules. it ran for about two weeks an then suddenly won't get ignition. the mechanic that replaced the timing told me that it's most likely the computer. trying to save money, I bought a used computer from the pick a parts… I made sure the serial numbers were the same. Do i need to take the vehicle to the dealership to have the computer reprogrammed before the vehicle will run? also, i installed the unit without disconnecting the battery… is that bad?
Old Dec 29, 2013 | 07:58 AM
mxmikie's Avatar
sounds like a crank sensor problem to me
Old Dec 29, 2013 | 07:39 PM
Dennryan's Avatar
"most likely the computer" Thats a fairly in general statement!
Some simple things you can do yourself to test it
Just turn the key on! Does's check engine light come on (if not check fuse)
Remove ele connector from TPS sensor check for voltage with a volt meter, you should see around 5 volts DC
There is a number of things that will cause no spark! You need to do more homework!
Old Dec 30, 2013 | 10:08 AM
johneric's Avatar
Thanks... i had a mechanic friend do all the tests but, his diagnostic equipment wasn't able to communicate with the Montero computer. He tested, fuses, modules and engine compression, and pretty much eliminated all but the crank sensor and the computer. i went to buy a used computer, hoping that would be the problem. It seemed a lot easier than replacing the crank sensor. The question is... if it is the computer that is the problem and i replace it, does the new (or new/used) computer need to be reprogrammed before the car will start? I really appreciate your advice.
Old Dec 31, 2013 | 02:15 PM
Dennryan's Avatar
Can't really say! If all the numbers match, plug it in and try it! I have done ecm swap with a 95 olds and it worked.But it was not what was wrong to begin with, Oh well I have a known good spare!
kevsb
Oct 15, 2020 10:22 PM
jwg727
Jul 17, 2010 06:47 AM
whill59
Nov 4, 2008 12:33 AM
SILVER
1st Generation
Aug 14, 2007 12:47 PM
nena604
May 18, 2005 03:52 PM
