2000 eclipse excessive pinging.
Old Jun 14, 2008 | 09:12 PM
yer_daddy's Avatar
Default RE: 2000 eclipse excessive pinging.
Ok, I give up. It runs great with the maf unplugged. It's going to auction on Thursday.[&o]
Old Jun 16, 2008 | 09:37 PM
dsm1990gsx's Avatar
When you replaced the maf did you disconnect the battery to reset the kam (keep alive memory)?
Old Jun 17, 2008 | 07:38 AM
My 00 GS was giving me troubleI ended up finding a crack in the intake manifold right by the throttlebody flange. I replaced the mani and a month later the new one cracked. had mitsu replace the next one and it cracked again.
I had a ebay short ram intake on the car that I feel was the suspect causeing the issue.
Just something to think about as the intake mani is very poor and thin
Old Jun 17, 2008 | 07:48 AM
another thing I am thinking. is the car should not be drivable with the MAF unplugged i mean it should barely idle. I think that my car acted the same way with the intake crack. MAF unplugged teh car ran idles good. I mean a crack will also causeun metered air pulled into the motor resulting in a lean mix and unstable startup and driving
Old Jun 18, 2008 | 06:01 PM
dsm1990gsx's Avatar
ORIGINAL: EMonz57
You can drive a car w/ the maf dissconected, I do it all the time w/ fords, I guess it runs off a default setting.
Old Jun 18, 2008 | 08:29 PM
ORIGINAL: dsm1990gsx
ORIGINAL: EMonz57
try doing that in to a mitsu. the car will NOT move at all esspecially a 4g64 motor. I know from personal experience my old GS would stall right out when the crack go bad on the intake mani. you know why it would stall? not because there was a crack but because the car essencially was running maf less. and with it unplugged the car will stumble and mis pretty badly maybe drivable but that very easily or smoothly.
its even worse with boost Mitsu MAF cars.
Old Jun 24, 2014 | 06:33 PM
Bcmjustin's Avatar
Hey. Any luck solving this problem. I'm having the exact same issue.
Gnarpen
Oct 3, 2023 12:12 AM
harleybob53
Jun 30, 2015 03:34 PM
mikemitsu
Mar 21, 2013 04:43 PM
paj_me
Apr 12, 2011 05:58 PM
mtc137
May 23, 2010 08:25 PM
