90 Eclipse Problem
Old Feb 15, 2008 | 06:06 AM
JStrateger's Avatar
Default 90 Eclipse Problem
I have a friend that just traded his car for a modded 1990 Eclipse gs-t. It has 550cc injectors, walbro 255lph, and I believe,a stockECU.
Anyhow, when he goes to about 5000rph the car starts to stutter and try to die. I told him it was most likely his injectors drowning out the spark and should replace them with smaller ones.
Also the car is near impossible to start when cold, I'mnot to sure about this one. His plugs might need to be changed. Is thisa common problem with DSMs?
Any ideas guys?
Thanks,
Joe.
Old Feb 15, 2008 | 09:56 AM
shreff99's Avatar
Default RE: 90 Eclipse Problem
What turbo setup does he have and has the car ever been tuned after the mods were put on?
Old Feb 15, 2008 | 01:28 PM
JStrateger's Avatar
The turbo setup looks stock to me but I wouldn't know if it was tuned or not. The guy he got it from said it got it from someone else and didn't have contact with him anymore.
The car hasn't been tuned to my knowledge, there are some computers in the golve compartment but I haven't checked them out to see what they are. One looks like it controls the fuel-air mixture but throws an "open pump" error, I'll have to take another look at it.
Heres the car domain with a list of mods:
http://www.cardomain.com/ride/2992250
Old Feb 15, 2008 | 02:17 PM
dsm1990gsx's Avatar
I would check to see what kind of fuel pressure your running at, I saw he had a ajustable fuel pressure regulator as a mod.
Old Feb 15, 2008 | 10:27 PM
JStrateger's Avatar
It's readingabout 60-100psi, I believe.
Old Sep 11, 2008 | 09:02 PM
xorion724x's Avatar
have you fixed this problem yet?
Old Sep 12, 2008 | 03:05 PM
dsm1990gsx's Avatar
ORIGINAL: xorion724x
Check the dates before you post.
ang099
Jun 28, 2004 12:15 AM
ang099
Jun 20, 2004 06:53 AM
Libra0281
Jun 1, 2004 12:24 AM
tjrcs
Oct 7, 2003 04:28 AM
