camshaft and crankshaft position sensor
Old Aug 20, 2008 | 12:49 AM
LuckyBadAzzBoy's Avatar
Default camshaft and crankshaft position sensor
I got a 2000 eclipse with a 3.0L eng. I got 2 bad readings. The camshaft position sensor and the crankshaft position sensor.
First question does the 3.0L even have a camshaft position sensor i looked for the part online it doesn't show.
The car has 150k miles i'm about to go ahead and change the timing belt and the crankshaft position sensor.
It just started idling awful and shutting off on stop lights and signs , if i put it in nuetral and keep it at about 1k rpm it won't shut off and it runs fine when i'm on the road. Any tips or ideas about whats going on. The plugs, wires, ignition coil and so fourth have all been already changed.
Johnboy13
Jun 1, 2011 04:40 PM
guitareagle1
May 13, 2011 10:07 AM
AnnaAmbrose
Dec 4, 2007 05:41 PM
rhothird
Jan 29, 2007 09:46 PM
michael49
May 16, 2005 10:30 PM
