ecm
Old Oct 7, 2007 | 10:03 PM
xslim69's Avatar
Default ecm
Will this work on any turbo ecu. All you need to do is solder a 1K resistor into the missing R129 position inside the ECU. If you look at some of TMO's pages, you will see the R129 and R130 resistors that the factory uses to program the ECU for different applications. With R129 installed, the ECU thinks it is one of the other 49 states and stops checking the EGR temp sensor.
martin
Jul 20, 2005 07:39 PM
borsno
May 31, 2005 12:51 AM
90Mirage
May 8, 2005 04:13 AM
Xit40
Jan 21, 2005 06:04 PM
cooley
Apr 2, 2004 03:03 PM
