help on position sensors
Old Aug 27, 2008 | 12:13 PM
LuckyBadAzzBoy's Avatar
Default help on position sensors
I got a 2000 eclipse with a 3.0L eng. I got 2 bad readings. The camshaft position sensor and the crankshaft position sensor.
First question does the 3.0L even have a camshaft position sensor i looked for the part online it doesn't show.
The car has 150k miles i'm about to go ahead and change the timing belt and the crankshaft position sensor.
It just started idling awful and shutting off on stop lights and signs , if i put it in nuetral and keep it at about 1k rpm it won't shut off and it runs fine when i'm on the road. Any tips or ideas about whats going on. The plugs, wires, ignition coil and so fourth have all been already changed.
[align=right] [/align]
Old Aug 27, 2008 | 01:23 PM
mitsupartsman.com's Avatar
Default RE: help on position sensors
that engine gets it cam reading from the distributor, how long ago did you change the wires?
before or after your problem started?
Old Aug 27, 2008 | 01:59 PM
before the problem i changed the wires last summer
Old Aug 27, 2008 | 02:19 PM
when you change the timing belt make sure the tensioner is not leaking or collapsed
a loose belt will throw your sensor readings off
Sephiroth
Feb 25, 2018 07:46 AM
Zearl Clark
May 1, 2015 10:14 PM
cristalle
Sep 13, 2006 04:01 PM
Sephiroth
Jun 4, 2006 03:03 PM
art1217
May 11, 2005 09:15 PM
