I need help really bad!!
Old Sep 25, 2006 | 11:00 PM
98_GstEclipse's Avatar
Default I need help really bad!!
So I got my S-AFC II in the mail today and I installed it a few hours later. After I installed it I turned the car on and noticed my idle is really high at 1500rpm. Then I take it out for a lil test drive and its running like **** Around 2000rpm it loses all its power so I shift to 2nd and same thing happens. What should I do!!! My car was actually running pretty decent before I installed it in and now its running like complete ****. Im afraid to mess with any of the settings cause I dont wanna mess it up anymore and I wont have the money to tune it for a lil while. Does anybody know if theres any reset to switch it back to default settings or can any1 help me out. Somebody please help me!!!
Old Sep 26, 2006 | 04:56 AM
Default RE: I need help really bad!!
Did you even tune it?
Also, do you have a wideband?
Do you have things like:- Boost gauge, MBC?
Old Sep 27, 2006 | 09:35 AM
make sure that you have all the settings correct to. Like the throttle position and set it for karman and the # of cylinders. For some reason some cars will actually want the cylinders to be set to 2 and not 4. Try both and see what works. Make sure everything is zerod out as well first.
Old Sep 27, 2006 | 10:20 AM
dont forget the arrow on the setup has to be the upward diagonal arrow the number of cyl may need to be set up for 2 not 4 and you may have wired the A\F wires in wrong like I did on mine at first
xLoveMeXoTenderX
Aug 29, 2007 11:26 AM
itsme71190
Aug 1, 2007 12:50 AM
DonikrDave
Dec 11, 2006 08:19 PM
zaskar888
Dec 20, 2005 04:01 AM
Richie03
Dec 12, 2005 11:14 PM
