Mitsubishi Lancer GLXi -92 Engine start problem
Old Oct 20, 2006 | 12:00 PM
Default RE: Mitsubishi Lancer GLXi -92 Engine start problem
Um what you could do is have someone stick their ear to the gas tank when you turbn the ignition on to see if they ehar the fuel pump prime or not. That will tell you if tis working.
Old Oct 20, 2006 | 06:56 PM
Arioch's Avatar
The fuel pump is working.
I turned it in for a checkup in a mitsubishi workshop today to get a definitive anwer what is wrong. It is certain that it is an electrical problem. However, I have been unable to find exactly what it is so far.
Old Oct 25, 2006 | 08:43 PM
Arioch's Avatar
One new ECU unit later the car is running perfectly again.
The first advice in this thread proved to be correct. Thank you all for your tips. I have learned a lot about the "new" car I just bought from this experience.
Old Oct 26, 2006 | 10:25 AM
Ive always found you learn the best when you get problems.
Old Oct 26, 2006 | 11:00 AM
Arioch's Avatar
So very true.
Funny thing is, after replacement of the ECU the C-Lock works as well. I did not think that the two would be connected. I see no sense in having the C-lock circuit connected to the ECU. But obviously it is.
alexi
Jan 10, 2025 06:35 AM
jpdaluz
Jul 7, 2015 05:30 AM
Werzal
Jan 9, 2011 05:18 PM
bluhills
Jun 30, 2005 09:05 AM
rannonj
Jan 3, 2005 04:10 AM
