mustang injectors?
Old Oct 27, 2006 | 05:50 PM
black_eclipse's Avatar
Default mustang injectors?
ok, i read like two or three times about using mustang injectors on eclipses, is that true? do they fit? what mustang years? i have an mitsubihsi eclipse gs 97 what injectors should i use, i want them biggers, i do not have any turbo , and i read about a Air/fuel mixture controller whats that? where can i get it and what brands? thank you
Old Oct 27, 2006 | 06:50 PM
Default RE: mustang injectors?
on a non turbo car there is no need for bigger injectors nor is there a reason to tune the A/F ratio because your really not gonna gain much from it. But just to answer you question. There are a couple of brands that sell air fuel computers. All they basically do is modify the signal comming into your ECU telling it that there is less/more air so that it supplies less/more fuel. One of the most common ones that everyone uses is the Apexi S-AFCII.
Gregory
Oct 13, 2005 03:45 PM
antomx
Aug 16, 2005 12:16 PM
Jeff E39
May 1, 2005 03:56 AM
puffy
Aug 8, 2004 12:50 PM
AutoX
Jan 9, 2004 02:43 PM
